Bad Emissions results
Venom SHO s7
Washington
I have a project 90 mtx that failed emissions pretty badly :
Cruise Limit @1800 RPM Hc(ppm) 150 CO(%) - 1 CO+CO2 (%) - 6
Cruise Emissions Hc(ppm) - 181 CO(%) - 2.08 CO+CO2 (%) - 15.08 O2 - 1.72
Idle Limit Hc(ppm) - 220 CO(%) - 1.2 CO+CO2 (%) - 6
Idle Emissions @ 820 PM Hc(ppm) - 427 CO(%) - 2.03 CO+CO2 (%) - 10.33 O2 - 7.46
The p.o. said the car sat for nearly a year, and since I started working on the car, I changed the oil, got new motorcraft plugs, taylor wires, completely cleaned out the intake and changed the gaskets, valve cover gastket set and will be putting on new 02 sensors that I have on my other car.
When i first start the car, it idles fine for the first few seconds, then the rpms drop to about 500 and almost stalls, sputters like that for a coupple seconds then goes back up and idles normal.
I ran the codes, and I came up with the Air Charge temp sensor being out of range, and something with a coil being bad. So I bought a new ACT and will use my other SHOs coil pack before I do emissions again.
Are there any other things I could do to get a better shot at passing?
Draining and putting new coolant maybe? Or a pour-in gas treatment that might help?
Im also going to try and find the SPOUT plug and unplug that.
And on a side note, would slack in the timing chains cause such bad emissions?
Thanks.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Slack in the timing chains won't really cause bad emissions.
How's the gas mileage in the car? Ever replaced the ECT?
Venom SHO s7
Washington
Good news, it passed. Umm i actually dont know the gas mileage, because i couldnt drive it since it had no plates. I replaced the ACT on top of the other stuff though. Those plugs and wires made a world of difference in the results.
Thanks for replying anyways AutoSHO
poffffd
