Michael Lanning
Thanks for all the help from my past postings. I have a 1997 sho with cams welded. The problem I have been having only happens every now and then. But what it has been doing is...it wants to cut off while driving down the road..all the dash lights will start flashing and the radio will go dead. Then it suddenly stops and drives with no problems ? I have replaced the Cam shaft sensor and the Crank Shaft sensor and recently replaced the trans safety neutral switch. Does anyone have any suggestions on what could be going on ? Ive wondered if it could be the vehicle computer going bad. has anyone had these problems and if they did...what was causing it. Thanks.
