b&g springs installation Q's
antz
I keel you
new jersey
I have a set of b&g springs i will be installing, the fronts are a no brainer on how they sit on the strut. the rear springs is what im wondering about which way is up. I have no pics, one side of the spring the coils are closer then on the other side so im wondering if they sit on the strut or does the other side. I cant compare to stock springs cause they are completly different. It might be a dum q's but thanks for any input I don't want to put them on the wrong way then have to do it again.
kevinspann
Don't take my advice.
Richmond VA
Do the B&G have dead coils - 2-3 really close together? If so that would be the top. IIRC the bottom may be a smaller diameter, the end of the coil will fit into place on the strut. It'll make more sense when you have it all in front of you.
antz
I keel you
new jersey
yes there are a few closer together on one end and the rears seem to have the same diameter on both sides thats why i was unsure the fronts have a smaller diameter on one side. thats why that is simple. thanks.
boat
Likes blue ones
Tallahassee, FL
If you would, post back here to let us know how they ride/handle. I am thinking about either these or intrax.
