axle
marv
chicago
I am having issue with right axle. I have replaced it 3 times with the same result.
I did the first time and then let shop do other times. About 1 month or 2 later the right axle starts making sqeeks and I can feel in shifter vibrations.
I am an aggressive driver but I don't think this is problem. The car is not stock all bolt ons and lightened. 92.thanksoh valeo clutch/stocktob
SHOMON
95 MTX
MEDWAY MASS.
Maybe it is a wheel bearing. Also on my atx I had some shaking in the wheel turned out to be the pass. control arm.
AREA 91
PA SHO SHOP
Area 91
Have you checked the shifter mounting points? I would also look at SFB's and MMT's. Also make sure that the innermediate shaft carrier bearing is bolted into place.:thumb:
Shoaz
Studly dood
Scottsdale, AZ
Have you checked the shifter mounting points? I would also look at SFB's and MMT's. Also make sure that the intermediate shaft carrier bearing is bolted into place.:thumb:
x2
If the halfshaft bearing is loose it'll vibrate the tranny, and also wear out a lot of stuff that shouldn't be wearing out.
I'd also check the motor and transmission mounts to make certain they're all healthy.
