Axle question Cardone part
tompumped
VT
First off is there any difference between the driver side axle in my MTX '92 sho vs. a '95 sho MTX? I'm pretty sure there isn't because on rock auto they list the same rebuilt axle for the '92 and the '95, just not sure why they don't list the new axle for the '92.
I was going to buy this part number 66-2008 Cardone Select new. I don't really need an axle, but my abs ring is cracked, so I figured i'd just buy a new axle and replace it when I replace the hub and bearing.
I was just going to put some jb weld on it to fill the gap, but then I realized it's a magnetic sensor so that wouldn't work. thanks
tompumped
VT
If anyone has any information that would be helpful. I can't find a number for cardone customer service. I tried rockauto, but that didn't work.
This is the part I was going to purchase, but I believe it's listed wrong.
http://www.cardone.com/English/club/members/customer/ecat_brands/imageinfo.asp?PARTNUM=662005#
This part is listed for the passenger side with M/T: (Just for reference)
http://www.cardone.com/English/club/members/customer/ecat_brands/imageinfo.asp?PARTNUM=662008
Has anyone ever used either of these axles? The 66-2008 is actually listed for a SHO, but the 66-2005 isn't.
AREA 91
PA SHO SHOP
Area 91
All 89-95 MTX SHO's use the same axles.
The only exception is that an 89 has NO ABS.
Therefore, there is no ABS ring on the axle.
You can move the ABS ring over if needed.
1995 FORD TAURUS SHO 3.0L 182cid V6 MFI (Y) : Drivetrain : CV Half Shaft Assembly Price Core Total
CARDONE SELECT Part # 662008 {[CV Half-Shaft Assembly] New}
Front Left; w/M.T.
$50.79 $0.00 $50.79
A-1 CARDONE Part # 602034 {[CV Half-Shaft Assembly] Reman.}
Front Right; w/M.T.
$58.79 $20.00 $78.79
A-1 CARDONE Part # 602031 {[CV Half-Shaft Assembly] Reman.}
Front Left; w/M.T.
MOTORCRAFT Part # TX441 {#4F1Z3B437AA}
Trans. code AX4S; Left
Trans. code AX4N; Left
Trans. code AXOD-E; Left (Only 2 Remaining)
$200.79 $0.00 $200.79
MOTORCRAFT Part # TX440 {#4F1Z3B436AA}
Trans. code AX4N; Right (Only 2 Remaining)
MOTORCRAFT Part # TX444 {#3F1Z3B436CA}
Trans. code AXOD-E; Right
Trans. code AX4S; Right (Only 2 Remaining)
$389.99 $0.00 $389.99
All 93-95 automatic SHO's (ATX) use the same axles, but are different from MTX axles.
Related Parts
1995 FORD TAURUS SHO 3.2L 195cid V6 MFI (P) : Drivetrain : CV Half Shaft Assembly Price Core Total
Front Left
$50.79 $0.00 $50.79
CARDONE SELECT Part # 662005 {[CV Half-Shaft Assembly] New}
Front Right
$50.79 $0.00 $50.79
A-1 CARDONE Part # 602022 {[CV Half-Shaft Assembly] Reman.}
Front Right
$43.89 $20.00 $63.89
A-1 CARDONE Part # 602020 {[CV Half-Shaft Assembly] Reman.}
Front Left
tompumped
VT
thank you. I called cardone apparently I can't use either of the new axles I have to go reman, but i'll just try to find an abs ring instead.
poffffd
