My transaxle has gone into Limp mode and I only have second gear. I can disconnect the battery erasing KAM and it will shift normally for about 20 minutes or one key on cycle. Once I drive it again, I get 2nd only. Anyone experienced this?
Actually, on most EEC-V strategies, FMEM modules and/or background executives are called once per background loop (which, depending on the strategy and the processor, can be up to several hundred times a second). FMEM can also be activated at any point during EEC operation, regardless of the current operating state (KOEO or KOER).nik97 said:FMEM will usually not take effect if a fault is detected only one(one drive cycle). If the same fault is detected again within 80 key cycles(think it's 80) then the failure mode stategy will be employed.
Correct.nik97 said:I dont think that the SCT's EEPROM tuning has the ability to interfere with Fords OBDII monitors and RAM.
As Chris has noted, the MLPS and TRS are one in the same to the factory engineers.nik97 said:Chris,...MLP..Manual lever position?..or TRS....are we talking about the same thing?
