automatic brake release
tommyturbo
California
when getting the a/c charged on my 95 atx I found a tiny broken vacuum line by the brake booster disconnected from the vac block up on the firewall. Fixed it but had not idea what it went to. found out what. put the car in drive the other day and the parking break released by itself. I thought only high trim line lx taurus's got those. anyway it's cool!
ShadetreeSHOguy
Postwhore
Dallas, Ga
Yep, the SHO is the top of the line for options.
And i just got my 93atx thursday and just found this out for myself. Very coold little option!
and 900 post FTW :woo-hoo:
mrecoolgar
SHO NUP
Hershey-PA
I believe the Ebrake assembly has a little manual release lever too.
In case the vacuum won't release it.
The 1966 Mercury Park Lane I learned to drive in had such a beast.
SHObill
'The Collector'
Rochester MI-48307Detroit
I swapped in a ATX EmergencyBrake assy in my 89 years ago ! since I have CRS, I don't drag the rear tires around anymore ! lol
kevinspann
Don't take my advice.
Richmond VA
So, if I had to leave the car running would the ebrake stay off, or could I re-apply it? My driveway is a hill :) Sometimes I have to juggle cars, so I'd need to be able to leave it parked and running for a minute.
SHObill
'The Collector'
then 'it' will not work for you! If the car is running, the 'E' brake is off! but...you could add a vac solenoid & manual switch, like the one used to vent the charcoal canister to the TB!
hawkeye18
Sorta cares
Norfolk, VA
That vac line is actually routed through the shifter mechanism. And, if it's broken, it'll cause a vacuum leak! Fun stuff, eh?
