auto lamp relay/issues
only1me
Missouri
Im new here registered today, and yepp I searched ,all 108 pages lol,before I got validated. I have a 91 and my autolamps dont work at all, I read in my search there is a relay that works the autolamps, Im assuming this is my problem.I can move my switch and nothing happens, no click, nothing.So where would this relay be,Id really like to fix this.
Also I have a airbag light code 4 ,safing sensor,where is my safing sensor located? Im assuming its the one just above my radiator.I wanna be sure though before I change it.I know about dissconnecting the battery, and the backup power supply.I just hate that annoying light.
Last I have the JBL system in my car, that has the cd player also. Anyways I have no idea how, but when I turn my radio on it comes on and my cd player to at the same time,the radio plays but my cd is stuck in my cd player and it shows it on the number 2 track.I figure Im already gonna have to replace the radio and cd unit anyways.The radio dont work half the time either,cuts out.Just wanted your thoughts on this.
I appreciate any advice,help given, thanks.
only1me
Missouri
got worse
It got worse ,my gear indicator light isnt on anymore, my hazards lights arent working, my turn signals up and quit ,my autolamps dont work( Im sure thats a relay) my rear lamp out light is on. All my lights are good, they were working perfect, even had new bulbs put in, still same problem.
My headlight switch works, the bright/dimmer part works, the windshield wiper part works, but the rest nothing.I need to fix this car I just got it recently and was about to have it inspected and tagged and now this .
Anyone know where to start?
only1me
Missouri
Well I proceeded to remove the multi position switch ,but I ran into a hang up my lock cylinder wont come out. I read thru the instructions on how to remove it, but it will only come out so far then it hangs up.I tried over and over but still same thing, with the pin pressed in it will only come so far then hangs up.
only1me
Missouri
Well got my lock cylinder out, and nailed myself in the nose doing it lol, it was hung on the plastic shroud.I got the multifunction switch out and apart its pretty green inside.
only1me
Missouri
Well I cleaned my multifunction switch inside really good,put it all back together and everything is working now as it should. I still havent found my autolamp relay though.
only1me
Missouri
Does anyone know where the airbag safing sensor is located, Since I got a code 4- Safing Sensor - Diagnostic Circuit Open or Low Primary Crash Sensor Resistance
Or could it be my primary crashing sensor also?
Thanks
