So I have an odd problem. I have an aftermarket Premier DEH440 with the standard black box and gray rectange ends to my JBL system. After I first installed it, I noticed that there was no negative wire pin for the front rear speaker. However, the front rear speaker still worked. However I had this scratching sound that would come and go as I would drive over bumps. That went away and now I have a whine that corresponds with engine RPM. The sound stays the same no matter what volume I turn up (so I can drown it out mostly) but when I am moving it can get pretty high pitched.
The two things I was thinking it could be are the little interference module coming off of the coil pack, or a ground issue. Any ideas? I double checked my butt end splices on the adapters, the connection to the speaker in the door, and the amp connections, and all seem to be tight.
