audio help
angelsmaybleed
shogun[914]
accord, new york
just got an aftermartket deck for my sho and i wanna hook it up ive tried to buy the adapter but i seem to fail to get the correct one every time...so im thinking about cutting the wires and doing it myself...does anyone know if there is a diagram that explains what each wire does or does anyone know what each wire does...i got a '92 mtx
spazmoid
RI
search around on the forum, i'm pretty sure its on here somewhere, and did you try the scoshe adapter from walmart? It works fine
zerg1024
NJ
i do aftermarket installs all the time for every kind of car. never had any problem
zerg1024
NJ
if anyone needs them done that lives in sout jersey i will always do it for free for a sho guy/girl
angelsmaybleed
shogun[914]
accord, new york
wish i was in jersy damn mine has some bugs that need workin out everything works but i have no sound out of any speakers...when i bought the car the stock amp on the passener side was removed and the stock sub so im guessing that might be the problem
JoesSHO
Reality
What do the speaker grilles say on the front doors? You may have a "premium sound" unit with no sub, in which case there would not be a sub or amp back there. Or, there could be a JBL system in there in which case the sub amp needs to be there to tie the system together I believe. It's been years since I saw a '92, so someone else needs to chime in here... But I do know that when I used either the factory sub integration harnes or the amp bypass harnesses, I never had an issue as long as I had the correct ones. Either Best Buy has them, or Wally World usually had them, most of the time in stock...
angelsmaybleed
shogun[914]
accord, new york
it says jbl on the door panels when i bought the car it had no deck and the amp and sub was removed so now i have to rewire all that back there i have an aftermarket amp and sub already so no i have to figure out how to wire all this
JoesSHO
Reality
Honestly- your best bet is to just rewire the stereo. If you get an aftermarket deck, you can just run new speaker wire to the doors and the back deck. It'll be a LOT easier, and the factory wiring is brittle and your new wiring would be rated for the bump in power too. I rewired my '93 and it wasn't bad at all. Problem is, the JBL system is all integrated. If you remove a piece, you need to replace it to get it all to run together. There is a plug in there that bypasses the factory amp, but I don't know if it will bypass the sub amp too. All you have to do is get a roll of speaker wire and run it to the doors and package tray in the rear, that's what I would do.
angelsmaybleed
shogun[914]
accord, new york
well i would like to thank everyone for their help especially 91 shonice who pm'ed me about it for a few days and got me off my but and into my trunk but i did end up getting everything running correctly...thank god...now on to the next thing...theres always a next thing
