ATX Transmission
s_h_o_fast
Minnesota
i had my trans rebuilt like 5-7K miles ago and now i just have 1st gear...i dont think it needs rebuild again...i dont drive it hard or excessive...no 7,000rpm shifts...could it be a bad valve body or a blocked oil passage or something not allowing it to shift...
Mike Kopstain
Arlington Heights, IL
It sounds like a valve body problem or less likely, a shift range selector problem. The shift range selector can be found on top of the transmission. It is shaped like a baseball diamond with a single electrical connector coming off of it as well as a metal rod. This part costs $35 and is swapable in about 15 minutes.
s_h_o_fast
Minnesota
a local transmission shop...its called Midtown transmission...the guy said i may have a sticky valve as well...
s_h_o_fast
Minnesota
if i drove like a banshee i could see it being a rebuild problem but one day i started it, went to go to work and it just didnt shift past 1st...
Cobraii976
I am an idiot
Could also be one of the shift solinoids in the side pan (valve body) I had lost 2-4 and swapped out one solinoid and regained 2nd, I would really have to belive this one is an electrical problem.
s_h_o_fast
Minnesota
cobraii how much do one of those go for if you know by chance...thats what i thought too...i got my receipt and the mileage on there and checked my mileage now and i have only gone like 2K miles on the new rebuild so i am sure its not that...thanks for the help
Huntervf
Bored now
Back in Michigan ... again.
At 2k on the rebuild it should still be under warranty. Of course I don't know the details of your particular transaction, but most rebuilt trannys come with at least a 6 month warranty.
crystizel
