ATX timing belt tensioner?
acsho
north carolina
Has anyone found a source for a new timing belt tensioner for the 3.2?
I have a junk ATX but the battery caught fire in it and melted the timing belt cover and belt all over the tensioner, so I don't know if it's any good. I don't want to put it on and have it fail in a couple of weeks.
Any suggestions?
Mike93
Go Sabres!!!
Buffalo, NY
I got mine through the dealer...for $106 after my dealer discount:)
I hadn't found any other place when I was looking for mine.
acsho
north carolina
Ok, I pulled one off the junker I have, it seems to be in good shape. When I compressed it a little oil came out of top where the piston is, is this normal?
Also I noticed that the tensioner pulley itself is adjustable, am I correct in this assumption?
SHOtimer
#2910
Santa Clarita, Ca
The oil leaking out is a sign that it is wearing out. I have seen good used ones with oil leaking. But, it is a sign that it is losing it's life. The new ones are bone dry.
Doug
acsho
north carolina
Doug
Should I use it or not? It wasn't leaking on the car, it just leaked some when I compressed it to put the alen wrench in to hold it.
93rev2sev
Hockeytown
There has to be a way to remove the piston, clean it up, fill it with a similar oil and reseal it...
SHOtimer
#2910
Santa Clarita, Ca
The original one in my SHO lasted about 160k, it started leaking oil around 140k ( to my knowledge). The oil leaking is just an indication it is wearing out. It still may work.
Doug
