hawkeye18
Sorta cares
I just wanted to let everybody know that I took apart my ATX timing belt tensioner today to see how it failed... basically, the rubber seal at the top of the unit got old and hard, got a bunch of little cracks on the circumference, and over time wore matching grooves in the shaft of the tensioner body. This caused a thousand microscopic leaks around the edge of the gasket, and over time the fluid leaked out.
This means that in order to rehab the unit, I would have to hone out the cylinder, which is easier said than done - the diameter is less than 1". I'm thinking a dremel with a polishing wheel might work, but I'd be worried about maintaining a perfect circle. Do they make cylinder hones that small? Because if they did, that would be perfect. Then, one would have to find a seal that worked - or get one manufactured (they look a lot like valve stem seals, but with rubber on the outside too).
In short, it's not looking good for a home rehab. I'm gonna try the ol' rubber rejuvination trick (which of course I have forgotten, but I know is on here somewhere) and see if it'll hold fluid. I plan on using ATF as it's pretty darn close to the same viscosity, and it should handle heat just fine.
My wife took our camera to wisconsin with her, so I have no way of taking pics (save crappy cellphone pics - I'm not gonna do that to you guys), so I'm gonna have to take it to work, disassemble it again, and take pics there. So... it might be a day or two, but you can once and for all see how these darn things work.
