ATX Question
95SHOATX
Rochester, NY
I was wondering if the speed control circuit/valve in the ATX could cause the car to "buck". It feels like a stumble or miss after it warms up around the 1500-2000 RPM range. It only seems to do this when the car is accelerating under a slight load and after it is warmed up. I am also wondering if this could also be wires and or plugs. No oil in the spark plug wells and I believe the wires and plugs are original (80k).
P
Prophet78
Guest
Someone mentioned that before, but I don't think that is the fix.
I think you got the problem figured out. It is the plugs and/or wires. I had the same problem. Toolboy79 stuck my car on one of their computers and found a cylinder that was mis firing. Stuck a different wire on and fixed the problem. Start with plugs, then go wires.
-Jeremy-
E-Mail Address: mailto:p[email protected][email protected]</A>
Webpage: http://prophet780.tripod.com
'93 Red ATX "Red Phoenix"
Rebuilt "Ford Quality Rebuilt Transmission" w/ Shift Kit
SHOShop CAI W/K&N
SHOShop Front STB
190 LPH Fuel Pump
Koni Inserts
Eibach Springs
Blazer Modded Fog Lights
Taylor 8mm Spiro Wires
SHO Filler decals
Fish Tanks
225/50/16 BFG GeForce T/A KDWS
