atx parts
npenson
Va
i was wondering if anyone has a rebuild parts list, i seen the sticky but that does not have part numbers listed on most, i have seen most of the parts listed on bulkparts, but dont want to start ordering the wrong parts.
thanks
npenson
Va
All the broken transmissions and no one has a full part # list for a atx?
npenson
Va
Well if someone with rebuild exp. would take a look and see if this list looks right it would help alot the only thing not on the list is the new forward piston but bulkpart. did not have a listing on it so i am guessing it is a ford item.
86006EA Master kit, AXODE / AX4S 1992-98 $127.02
B86020 Band AXOD / AXODE / AX4S / AX4N OD $15.38
B86026 Band AXOD / AXODE / AX4S Low / intermediate $31.39
A86915 Band GUIDE, AXOD / AXODE / AX4S, $1.80
86030 Bushing kit, AXOD / AXOD Early 1986-93 $26.55
86420EAK Solenoid Master kit, AXODE $129.81
T86165E TransGo Shift Kits AXODE / AX4S 91-up $46.99
S86165B Superior **** dam kit AXOD / AXODE $50.61
F68ESHO Converter, AXODE *Order by codes $157.50
T-2400 Tool, AXOD, 3 Piece Lip Seal installer PROTECTORs $72.00
Q86673B TURBINE SFT, AXODE/AX4S/AX4N ( $15.95
A36650B Sprag, E4OD overdrive, 34 element $50.73
Total: $725.73
projectSHO89
SHOless In St L
Only a handfull of us have actually done our own ATXs, the rest have been done by a shop.
That's www.bulkpart.com not bulkpartS for anyone else, BTW.
Here's what I ordered back in Feb:
Code Name Quantity
Price/Ea. Total
OC-1679 Hayden Transaver Plus, extra heavy duty & standard
installation kit 1 $54.82 $54.82
86400EH Technical manual, AXOD / AXODE / AX4S Update Handbook
1 $16.50 $16.50
86006EA Master kit, AXODE / AX4S 1992-98 1
$127.02 $127.02
B86026 Band AXOD / AXODE / AX4S Low / intermediate 1
$31.39 $31.39
B86020 Band AXOD / AXODE / AX4S / AX4N OD 1
$15.38 $15.38
F68ESHO Converter, AXODE *Order by codes 1
$157.50 $157.50
D36436 Sensor, OUTPUT VSS, Cable driven, .870 inch dia.
1 $23.37 $23.37
S86165E Superior Shift correction package AX0DE 1
$57.63 $57.63
86030A Bushing kit, AXODE / AX4S 1994-UP 1
$17.69 $17.69
86200 Thrust washer kit, AXOD / AXODE / AX4S / AX4N, 1986-UP
1 $10.21 $10.21
86431 Solenoid, AXODE / AX4S EPC , 1991-UP 1
$61.49 $61.49
Shipping: UPS ground shipping /
handling: $16.50
Sales Tax: $0.00
Total: $589.50
I ordered the T2400 kit and the required spring compressor from ebay vendors.
The tech manual I ordered wasn't needed. I did not use the bushing kit. The thrust washers were used but probably weren't needed.
Do add the VSS. If it fails afterwards, you will wish you had.
I used the Superior shift kit instead of the Trans-go on the recommendation of Mike Yeager (SHO#7). I'm happy with it now. I did not use the **** Dam kit. Also, on his recommendation, I bought the largest stacked cooler available.
Plan on replacing the forward clutch piston with the steel one. If the transmission has never been replaced, it's still got the aluminum one in there. I bought the steel piston from a local dealer for about $60. Bulkpart does carry it, look under DRUMS, about $70.
I also reused my turbine shaft and sprag as they were in good condition.
When diassembling, TAG the EPC and TCC solenoid leads. They're physically interchangeable. Don't ask me how I found that out. The shift solenoid leads are not interchangeable.
I also bought a copy of the ATSG video off ebay along with the rebuild handbook. The video gave details about how to tear down the tranny and tips on how to put it back together. Things it didn't cover were VB/pump service and the individual pistons/drums. Overall, it was worth it to me since I had never been inside any auto tranny before.
The Ford Service CD (or the factory AX4S manual set) is mandatory.
Ask if you need anything else.
Steve
npenson
Va
Thanks for the help, I wanted to make sure I was on the right track. I just replaced the vss about a week ago thats why its not on the list, as far as the video and spring compressor i will look on ebay for those. Is the ATSG tech. manual (not the update manual) the best to have or the update manual, I all ready ordered the tech. manual.
projectSHO89
SHOless In St L
The ATSG manual and its update are pretty much irrelevent if you have the Ford documentation. It's just a reprint of the Ford (early version) procedures. A lot of the info in the original book is for the AXODE/E only.
My local O'Reilly's could have gotten the spring compressor for me, but I had already ordered one by the time I found this out. If you are relatively handy and have a decent shop, you can probably make your own as I recall someone reported having done. Cost was less than $80 for the K-D # 2398 I bought. This tool is useable, but I wouldn't but it again. PITA.....kept popping out of the ring groove when pressure was applied to compress the spring. If I had to do it again, I'd buy the ATEC T-0158-HD for just over $100.
Steve
rudedog
madness sucks
Houston, Tx
I know this is an old post, but so far it's been pretty helpful as to what I shoud get. I'm fixing to make an order from Makco and was noticing on their website that they have listed a low/int band number B86020 AND B86020-g with a blue dot. Would there be any difference? Short of taking mine apart before I order parts, is there any way to know if my unit will require the "blue dot" piece? Thanks, Rudy.
projectSHO89
SHOless In St L
Give them a call or email them. They're pretty good about supporting customers.
FWIW, the "blue-dot" is specc'ed for 95-97 AX4S, probably doesn't apply to yours.
Steve
projectSHO89
SHOless In St L
thanks Steve, T2400 kit, what is that? is that the servo tools?
The T2400 kit is the lip seal protectors. They are needed when inserting the pistons into each of their respective drums. Keeps the circular seals compressed so that you can get the thing inserted without damaging the seals.
Steve
