SASHO91
Zoom Zoom
Did a quick search but I can't find anything....
My buddy has a 93ATX which the P/S pulley has stripped either the pulley itself of the splines on the pump (from what I can tell).
The pulley can spin independent of the pump, but it can still turn it with some force.
Anyone have suggestions on how to remove the nut from the pump? It's not as easy as it sounds, as the pulley is not seated properly on the splines(as they are probably gone) so the pulley is very close to the nut making it hard/impossible to get a ratchet in there. Which has a problem in itself as the pump is still turning.
What i thought of doing was putting some vise-grips on the "stud" and use some needle nose vice-grips for the nut. This seems to be the only option.
