ATX motor mounts
Daedalus
Gen3 noob
Simi Valley, CA
I took my car in for an estimate on the tranny, and they called back and said that two of my engine mounts were broken. They wanted ~$750 to replace them. Is that reasonable? I've found numerous threads about MTX mounts, but nothing about ATX mounts. Any help would be appreciated.
Thanks!
TYSHO
Earth
Considering the mounts new from Ford are going to cost you $250+, the rest is labor charge and quite high. I wouldn't let them charge you over 4 hours for the set.
Yamaha V6
SHO Enthusiast
Rhode Island
Mounts are available aftermarket, be careful of the quality however - I had a solid one shred on me at the strip.
If you get stuck I think I have some used stock ones I'd let go cheap.
Daedalus
Gen3 noob
Simi Valley, CA
Correction: $750 was the total cost for 2 motor mounts, installation, fluid flush, filter, estimate, plus beating the bottom of my tranny pan flat again (Must have hit a rock or a big pothole :( - man do I need new suspension). They said about $345 for labor.
I'm probably going to go ahead with this, since I don't have access to a shop right now and my landlord frowns upon tearing cars apart in the apartment complex's driveway. I can get away with tune ups, brakes, etc. but I don't know about an engine mount.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
i got motor mounts from my atx to mtx swap and they looking in good shape except the transmission mount which got torn. if your interested i will give them up for cheap since im trying to clean up spare parts
