ATX knocking solved....
SHOtimer
#2910
Santa Clarita, Ca
Well, my new 1.6k motor made it's first trip (300 miles) home from school this weekend. I turn the block and roll down my window to hear my motor clacking....I of course was not pleased. I pulled it into the garage, the knocking was not pleasant, but didn't sound metal on metal. So, I pulled the upper timing cover off and sure enough the timing belt was flapping away. So, saturday morning I tore apart the front of my new motor (which I figured I wouldn't need to touch for at least 30k) and found my 10 year old timing belt tensioner not doing it's job and covered in the black oil that was originally inside of it (everything was spotless when it was put together). Installed my new Ford tensioner that I thankfully have stock piled and buttoned it back up and was good to go.
Did the job start to finish in 2 hrs, which I didn't think was too bad, most of it was from memory at this point.
Now, I am gonna get another tensioner to put in my drawer so I will feel safe, for another 10 years.
Doug
SHOtimer
#2910
Santa Clarita, Ca
Well, the motor has only been in there for a month or so. So, I had a fresh sense of everything, and it was all clean. Which makes for easy work.
Doug
40BelowSummer
Puerto Rico
hmmm....maybe thats my ATX's knocking noise. Before I pull the pan to change the rod bearings I should look into that.
SHOtimer
#2910
Santa Clarita, Ca
It sounded different than a rod knock - but it is easy to check, just pull the upper timing belt cover, and start it up. My belt was flapping 1-1.5 inches between the cam gears. You will know very fast if it is the problem.
Doug
TYSHO
Earth
SHOtimer said:
It was a timing belt tensioner, not a cam chain tensioner.
Doug
I think he meant that at first because all of the failures like mine, yours, tom's, seanmc, and others that I can't seem to recall.
40BelowSummer
Puerto Rico
Doug
Yeah it isnt so much a rod knock, it reminds me of a faint diesel type noise. Ill have to remove the cover one of these days.
SeanMc
NoMoSHO
I just put a stethoscope to the belt cover and it was so loud that I couldn't keep it on there for any amount of time. Pulled the cover off, and sure enough, there was a lot of play in the belt. Another sign is when you get to a certain rpm, it goes away. I get to 2k rpm, and it's like nothing is wrong. I'm parking it until Weds when I go to GoofSHO's place because he has power tools (and tools in general) :D.
SHOtimer
#2910
Santa Clarita, Ca
I guess mine might have been worse than Sean's because I had it up to 5k and the belt was still flapping....
Doug
SHOtimer
#2910
Santa Clarita, Ca
revhardSHO said:
Wow you managed to find a brand new motor, how did you manage that??? How much did you pay?
I rebuilt a 3.2 that I had. Boiled the block, new freeze plugs, new rings, new bearings, fresh hone, polished crank, and reused the stock pistons....runs like it is brand new though... :corn:
Doug
