ATTN: All who have Roush springs installed...
wuzzzer
MN Moderator
St Cloud, Minnesota
What did you do to your cars to get them back into factory spec alignment? I took my car to a recommended local auto facility and they said my car was too far out of spec to adjust without some type of alignment kit.\
I noticed that the SHO Shop has a rear tubular control arm set, but at $399 I'd like to hear if there's anything else I can do first.
Let me know guys! Thanks!
Mark
'97 Pacific Green
http://www.picturetrail.com/wuzzzer
Roush Sport Lowering Springs
Porterized
K&N Filtercharger
Rhino mufflers (909 series)
Nakayama Racing Sports tips
17" Team Loco #150 wheels/Dunlop SP Sport 4000 tires (spring/summer/fall)
Bridgestone Blizzaks (winter)
[This message has been edited by wuzzzer (edited 02-18-2002).]
jedhead
westminster,ca
wuzzzer:
I know on my '91 the rear control arms had concentric bushings that allowed camber and toe in and out adjustment. For the front I installed camber plates to do the alignment. I had to do major alignment changes when I installed the SS Linear springs. You might check into camber plate and see if you have concentric bushings in the rear.
Bob
Venom 800TT
Beavercreek, OH
My Gen3 Non-SHO has Eibach's wich give a greater lowering than the Roush springs. All I needed was a regular alignment at the shop. About .5-1.0 rear camber and very little front camber is what I ended up with. Not sure if this was any help. Later.
Venom
<small>[ February 21, 2002, 09:24 AM: Message edited by: Venom 800TT ]</small>
SnoSho
Circle Pines, MN, USA
On Gen1/2 you can put washers under the rack bolts to lift it abit and give it a straighter line not sure about the rears though.
Tim M.
