MilTownSHO
In my 92 the A/C would cut out once the car had been running for a bit, if you turned it off, it would work for awhile agian. My previous red 92 had the same problem and was fixed with the A/C clutch regap procedure.
So tonight me and 93redatx attempted to regap the new 92's A/C clutch only to have difficulty getting the bolt that holds the clutch on off to access the shims. It was getting late, so we gave up and I went on my way home.
But...now I notice if I have anything on that uses the compressor (Auto setting, etc.) and I get on it (aka floor my car), I occasionally get this high pitched sound which I am relating to what we did tonight for one reason. When we were trying to get the clutch out to get access to the shims, we were using a screw driver to attempt to stop it from spinning so we could remove the nut. Is it possible I damaged the clutch more doing that?
My other thought is, my car has underdrive pulleys which I know can make the A/C not work as well in the city, but it shouldn't get flat warm right? I can see the clutch stop engaging after awhile.
Any help is appreciated!
