customperforman
I have been battling with some dark forces from the center of the earth or something. I have erased all codes and replaced neccesary parts required to do so. I had another cam sensor go bad and had several codes besides that this past sunday. Today I replaced the egr pressure feedback solinoid, IAC and another cam sensor. Drove it a few miles warmed it up checked codes none i thought. On the way home it ran so good i opened it up to see what it would do. When the secondarys kicked in and i got up to a certain speed and around 4500 rpms the tac whent dead and engine started running rough barely made it home. Anyway now the tac sometimes works, its hard to start and I have the floowing codes in this order. 121 tps its new, 221 dis module, hasntr been replaced and 214 cam sensor new. Myt question is what is causing the cam sensor to go bad or is it another problem making it look bad and the tps is new so i shuldnt have that code. By the way all 60k has been done top and bottom This dam thing wont run good for more than a week at a time it seems and then I have toi work on it. I am about to junk it. 94 sho with 111,000 on it and its an atx. Could it be a bad ecu throwing the codes?
