somedude_001
the rear of the subframe is sitting fine and snug just had to clean up some rust and a few taps of a hammer and it went togeather fine but the front of the subframe has 4 small oval dohikies sticking out and the subframe bushings don't interlock as much as I'de like to see should I grind out the oval things which would be tough to do given the location of them or should I leave them there and reassemble the subframe, the cups interlock about 1/8 inch in the front (the front are the ones in question) and significantly more than that in the rear.
