As brake line kit from Goodridge
Mn
I`m about to make brake swap and wanna make firmer brake pedal feeling. the only ss lines i found are Goodridge G-Stop SS Brake Line Kit. I know some of you guys use it, so my question does that lines have swivels on the fittings? nothing about that in the description. is that kit straight plug n play or requires some additional labor or parts to installation? And what about brake fluid anyone use anything better than oem?
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Dot 4 any brand. I change out mine once or twice a year as it gets nasty dark. I dont bleed it out, I suck it out of reservoir with a 30cc Tume syringe with 2 ft O2 tubing. 2 or 3 times usually clears it up. I had the SS kit, it did firm up nicely. Plug n play as I recall. Looks nice on too. I spray paint the calibers with color if your choice, I used red I do light blue now. I use either caliber high heat paint or high heat engine block paint from pep boys. I repaint ever 2 years. Salt n NJ street crud takes it toll. Orange, red, blue and yellow I have seen....
Mn
Thanks man
SaveMelMac
Texas
Did this about a month ago. Plug and play. I did not feel any difference over stock. Used Castrol dot 4 highest rated boiling point for off the shelf brake fluid, without stepping up to the fancy racing stuff.
shootinirons
