are V3 T-trim and v2 t-trim same housing?
BlackonBlack89
burlington county,NJ
So I found out that vortech pretty recently came out with a V3 T trim. If u don't know, v3 is self contained oil and I knew that had smaller versions available already but just saw a used v3 t- trim for sale on the vette forums. ( Yep same blower for a vette on a little 3.2) Anybody know if they have the same bolt pattern, and will work with a old SS bracket? I may just have to call vortech.
And anyone supercharging this is such a better way to go. It's not hard to tap the oil and pan but man its such a better idea. Much easier install, no line running across the motor and no worry about the drain line.
kevinspann
Don't take my advice.
Richmond VA
I think the V3 has the same bolt pattern and is meant to supplant the older S/Cs. Like you said installation is easier on the SHO considering how the oil feed and return lines need to be run. If I had a bracket, I'd probably be looking for a V3 to use.
I'm guessing the Vette uses a CCW rotation blower?
