Well I recently got a 1992 MTX SHO from Firespirit in excellent condition, taken care of and kept up with maintenance regularly, most recently was a second 60k @ 190k, and the engine is now at 205k. The only mods performance wise done to it so far was just the dynomax catback exhaust.
I was thinking of doing performance mods now to it to make it nice and good, but i had a few questions.
Is it worth it to build up an engine with over 205k on it even if its in good condition? its a 3.0. and What of these mods will work with a 3.2 swap?
1. UDP - Shouldn't have a problem working with a 3.2 swap if I do it, planning on getting this first.
2. Magnaflow Y-Pipe - I know this seems to be a big mod for opening up power, and i dont see it having any problem working with the 3.0 or 3.2.
3. Ported Intake Manifold - This is where im not sure if it will be swappable or not, i was thinking of getting the "stage 2" from Shosource with the full porting. If its not swappable, would it be worth it to get it on this high mileage of an engine?
4. Big Bore Butterflies - Again, same questions as above.
And with all these mods done and installed properley, what kind of gain should I expect from a MTX SHO?
Thanks alot.
Thanks alot.
