sho 'nuff
So today I tried to fix this problem I have been having with my rear window control from the driver's side door. I took off the cover to the master controls and sprayed the copper pieces with electrical contact cleaner.
Thinking this solved the problem I put the cover back on. Nope. I can get the rear windows to go down but they won't go back up. I take the cover back off...and try to manually raise the window by pressing the proper contacts down with a non metal object. It worked for both rear windows.
So does this mean I need to replace the whole switch assembly because of these two buttons that just don't seem to press down the contacts far enough anymore?
