PhenomSHO
You don't have to worry about the fuel pump code. The code usually means your car was stalled at some point. Clear the codes, and run the test again. If the code comes up, then there's something wrong, but otherwise, I think you are good to go.
Crank sensor.... You can't see it, and it takes time to get it replaced. It's under the lower timing belt cover right above crank. You will have to do front 60k, but I'm not 100% sure it is crank sensor so yeah.
Oh alright, so I will do that 60K once I get some money. I cleared the codes and the code comes up again, I think its just the constant power running to the fan and the fuel pump. I think that would make sense.
