Anyone have pics of a SHO on Intrax?
MG
Northern California
I searched and just found a bunch of dead links. Anyone have a pic of their car before/after having Intrax springs installed? Thanks!
yamahaSHO
E85 whore
Arkansas
Here is a picture of Terry's(twr) SHO.... He has one coil cut up front.
Hope Terry does not mind me posting his pic...
MG
Northern California
Cool, thanks, do you have a side shot? That doesn't look super low, but apparently it's one of the the lowest springs out there?
PROPHET
Well-Known Member
Tonytown, Texas.
Heres some pics of mine with intrax springs.
it's already low enough may look better with another coil cut but i would not suggest it.
SinisterSHO
Rust free
630, IL
Dave, none of your pictures load for me. Even the one in the post a pic thread aren't working. :shrug:
Dave Kegel
Chicago suburbs
MG said:
Your car looks like it tucks more than the rest, are your tires the same diameter?
The wheels are 17 x 8, 40mm offset. The tires are 235/45-17. It's all in the offset, they actually fit in the rear pretty well. I have not had to trim the fenders, only a little at the top of the plastic ground effects where they meet the wheel lip.
Dave
ghostrider
Mt Juliet, TN
That is one hot ride you have there Terry! So the rears are "stock" intrax and the fronts have a full coil cut?
FAST4DR
Here's mine on intrax. It looks ok in this picture because it's heading downhill a little, but when on a flat the front sits too high for me. I am going to cut one coil out like terry did.
Will
MilTownSHO
Horicon, WI
Intrax here also, the front raised up once the aluminum subframe bushings got installed. It doesn't look all the lowered, looks how it should have stock, I can't wait till some 17's! :D
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
Side by Side
hey jason, rememebr the day we took pics... and the one of the fronts of our cars.....
here's a little compairison for you guys, stock/intrax
:thumb:
Welll it looks better in a higher resolution....
SinisterSHO
Rust free
630, IL
Well, I'll post another picture of Jason's car. His on Intrax, mine on Eibach's. I can see the difference.
twr
whoohoo
half-way there, I think.
Correct.
Good point Will, I never thought aobut the possiblity of the Aluminum SFB might raise the car.
313tiger
