38SHO
#1 Oil Abuser
I heard this 89 has a 91 engine?
so I would assume, if that was right, and if they swapped over everything, that it might have the bigger flywheel.......
I ordered up the new clutch kit today, its for the bigger 91-95 style flywheels, if I get it apart tomorrow and its the smaller size, I might be stuck, does anyone here locally have an extra flywheel of that size laying around?
the clutch is making all kinds of noise, now it makes noise at any gear with clutch in or out... when it works... and when in nuetral.. but not as loud. I think parts of the pressure plate are breaking up.. it kind of sounded like a fishing reel with the drag going out when you tried to do downshifts.. now it just got 10x worse and sometimes quits working at all.. I think maybe a piece of the pressure plate broke off and is getting stuck behind the bearing or arm and its not always releasing.... usually when its F'ed up the pedal is about 3x harder then it was when working normally.........
welp I got half of it apart today, I see a few issues haha.... and the exhaust
broken subframe, right where the front mount is the thing is cracked in the inside edge along the engine..... I guess I'll run it... or try to weld it crappy...
I'd like to swap over my knuckles and 99SHO brakes from my green car... they are much better then these brakes... but I think my driver side needs a new wheel bearing.. might as well change it anyhow, I just changed the pax. side a couple weeks before I stopped driving it.....
also got a crapload of codes....... most notebly
14 Ignition pickup was erratic - Ignition Systems
19 (O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
(R) Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
my snapper scanner said it a little bit differently on code 19, but these are the descriptions from SHOPP....... for 19 I think it mentioned CID.....
when running the paper clip way I was copying down codes wrong, thinking I had 41 and 91.... but that is not the case.....
any help appreciated
