anyone got a ******?
SuperHO
Mental Patient
St. Joe, MI
I've been considering this, since I don't care at all about NVH problems....
http://www.ingallseng.com/parts/ETD/******.htm
thoughts?
Mr Anonymous
Tire Wall
Why waste money on gimmicky shit like that? Just get a bunch of DOM tubing and a welder and go *********. You could basically prevent the motor from ever moving.
Vnuk1
Mr. Mayhem
Minnesota
93rev2sev
Hockeytown
it's a "one size fits all" steel rod with brackets.
Besides, we have this. OEM units are liquid-filled, and tuned to the mass of the engine.
1993MTXSHO
Its a Taurus...
Jersey
Solid engine torque dampers can be dangerous too so be careful. Solid or reinforced engine mounts are a better way to go. If your engine mounts fail, that puts all the strain on the dampers, and I have seen cars in which this happened and it crushed the shock towers in, so just a little heads up;)
SHObill
'The Collector'
Rochester MI-48307Detroit
After 100K the stock dampeners are worthless! I never pulled a good set off a car. Remove them & all the brkts & save some weight! They are band aids for weak mtr mtg!
-& I've seen solid dampeners break the brkts- but no way can they crush strut towers. Even good solid hits to total the car & strut towers are fine!
HotRodKid
mmmmm ... turbo
Western NY
liquid filling is for vibration more then it is for movement
while solid mounts / reinforced mounts are great, they arent the answer to everything. the engine has the leverage advantage on the stock mounts because they are rather close to the rotation center line.
having an engine dampener like this allows you to place the dampener in a location that gives the DAMPENER the leverage advantage, hence why dampeners are always mounted high on the engine
the sho however would present a mounting problem due to the transverse layout. i suppose that a bracket on the accessory end of the engine would work, maybe make a 3 tube mount that ties into the frame at 2 points and also extends to the strut tower, and have the dampener occupy the space where you would mount a centrif. supercharger
but the question is, how much good would it do on a car that already has upgraded engine mounts ? and who wants to spend the $ to find out ?
1993MTXSHO
Its a Taurus...
Jersey
Nick, quit acting like the Beav's mom. We've mostly all been around the block. :rofl:
I was simply voicing my opinion to brign up a possible problem, maybe the car it happened on was weakened by rust or a previous accident, but that being said I run solid dampers on my car, but I also have reinforced mounts.
GASHOGUY
JDM/DTM convert
Kennesaw, GA
SHOShop used to make the factory dampers solid. I rode in a car that had them. Worst riding SHO ever!
