Answer to "Weird Lighting Problem"
kd7kmp
Springville, UT, USA
I got the car back from the dealer today. :) :) The problem was in the resistor wires for the Lamp Out Warning module. These wires had completely burned through their insulation and caused several shorts to power and ground. :eek: :eek: This, in turn, caused other wires to burn through their insulation. :madflame: Anyhoo...we got the bad sections of wire replaced (thankfully it was all contained in the harness next to the driver's side back seat) and everything works dandy now. I did have to unplug the Lamp Out Warning module so the dash light won't stay on all the time. Thanks for all for your time and help. :thumb:
Kevin
93SHO'nOFF
And you are...Who???
Lehigh Valley,PA
Hmmm....Interesting..... Glad to see it got repaired and the head's up if I ever run across one with same concern. But most of all ..........glad to see those door adjar switches are well lubricated! Right Mark?Only having a little fun,don't take me seriously.
Later! :thumb:
