kd7kmp
I got the car back from the dealer today.
The problem was in the resistor wires for the Lamp Out Warning module. These wires had completely burned through their insulation and caused several shorts to power and ground.
This, in turn, caused other wires to burn through their insulation.
Anyhoo...we got the bad sections of wire replaced (thankfully it was all contained in the harness next to the driver's side back seat) and everything works dandy now. I did have to unplug the Lamp Out Warning module so the dash light won't stay on all the time. Thanks for all for your time and help.
Kevin
Anyhoo...we got the bad sections of wire replaced (thankfully it was all contained in the harness next to the driver's side back seat) and everything works dandy now. I did have to unplug the Lamp Out Warning module so the dash light won't stay on all the time. Thanks for all for your time and help. Kevin
