Another victim of Electrical tape!?!?
digsj7
Digsj7
Columbus ne
This is starting to **** me off a little! I have an airbag light that is flashing. It flashes 4 times, then pauses, then flashes 2 more times. It is a 95 ATX. Anyone have any ideas on how I can get rid of this!? :frantic:
digsj7
Digsj7
Columbus ne
This is the code.... 42=LH Primary Crash Sensor Feed/Return Circuit Open. Could I just disable the airbag or close that return circuit? Any idea on where it's located?
93rev2sev
Hockeytown
Yeah. You probably need to replace the drivers side crash sensor, attached in front of the drivers front wheel, behind the plastic wheel well liner, bolted to the unibody. There:
jmpSHO
Massachusetts
Code 42 is the center radiator primary crash sensor feed/return open. You probably have a short in one of the three wires that run from the sensor to the diagnostic monitor.
