Another SFB question!
JB
Saginaw, MI, USA
Dumb question perhaps, but I'm thinking about machining up some aluminum SFB's from the dimensions posted in this group.
Not having actually poked around under the car yet, I'm wondering why the bushings are two-piece? Why not just one piece 3" diameter X 2.1" high?
JB
jthomas68
Area 51
One piece is under the sub frame,and the other is above,inbetween the frame and subframe.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
94shoboy
south shore, mass, usa
where did you get the dimensions? can anyone tell me exactly what kind of aluminum it is? i could probably have them made in a day or two if i knew i could find the specs on them. thanks
jthomas68
Area 51
It`s T6061 aluminum,pretty standard stuff.I`ve posted the dimensions before on Delphi i think.
Jeremy Thomas
Juiced 91+
jthomas68
Area 51
Not any more,i gave then to Bruce(SPT)and didn`t keep a copy.They are on the car now,so i can`t get them again.
Jeremy Thomas
Juiced 91+
JB
Saginaw, MI, USA
Here's the specs you published in February, Jeremy, which got me thinking about making the bushings.
<quote>
They come in 2 pieces.Part one if you look at it from the side,looks like a "T",because it has a "tower" cut on it.Part two has a "dish" cut into it that the "tower" fits into.That being said,here you go:
Part 1:
3" rod.Overall height is 1.400,machined on both sides.The tower is 2.06 dia,and is .400 tall.There is a 13/64th`s(.484)thru hole in the center.
Part 2:
3" rod.Overall height is 1.1,machined on both sides.The "dish" is 2.067 dia.,and is .400 deep.There is a 13/64th`s(.484)thru hole in the center of it also.
My only question is on the hole size, I assume that you meant to type 31/64th's not 13!
JB
jthomas68
Area 51
Sweet,people actually listen to me
Jeremy Thomas
Juiced 91+
94shoboy
what else besides the bushings is needed for install? can you reuse the factory bolts? thank you soooo much. hopefully i can get a price on making these by the end of the week. if its cheap enough i will start a group buy in january.
