Another None Starting SHO
Tekarus
Austin, TX, USA
OK you guys, I don't want to repeat previous post on this subject of SHOs not starting. But the search function on this forum does work as well as it used too. Here are my symtoms:
CAR DOES NOT START. (ran fine until I parked it overnight)
1)I'm getting spark.
2) There's fuel on my plug from trying to start it so much (and I smell it after 10 or more tries). So i'm pretty sure I'm getting fuel.
3. Tach read 300 - 500 when cranking
Tekarus
92 SHO blk/blk
J
Jeremy Hohn
Guest
Is the tach moving at all when you try and start it? If it isn't I suspect the cam position, or CID sensor could be the problem.
Jeremy
1993 atx 122k miles
-PIAA headlamp bulbs (thanks Fratperformance)
-fish tanks installed
-fog lamp mod w/ blazer fog lamps
-6" 5% tint border on windshield
-black body filled lettering
-wclewis "powered by yamaha" badges
-Sho Shop Cold Air Induction Kit
-Lund blackouts front and back
-cincysho colgan half bra with "SHO" lettering
-KVR chrome cadmium plated rotors with carbon fiber pads
-Sho Shop cat back system with magnaflow chrome tips
-Performance Plus y-pipe
-TX personalized plates "SHO FUN"
-Shoshop underdrive pulleys
-Shoshop 80mm MAF
-60k completed by Sdpatt
-Redline atx tranny fluid and water wetter
-Ted Breaux LPM
-D4U1 computer upgrade
-Rebuilt 94/95 AXOD tranny with TRANS-GO shift kit
pittsburghsho
pittsburgh
Nope, I replaced the cam sensor and battery at the same time and have been runnin fine ever since. Tho old cam sensor was cracked and the car seems to be a little more peppy after it was replaced.
Tekarus
Austin, TX, USA
You know, I read somewhere that someone unplugged their CID and it started up. The guy kept it unplugged until his replacement arrived. I would like to know how feasible that is, but shucks after taken off the intake and moving the powersteering res. you might as well replace it.
Tek
Tekarus
Austin, TX, USA
UPDATE
The decided to try to push start. "Popped" the clutch and she fired right up. I shut the ignition off and tried to start again. She fired right up. So this morning I drove her to work (I put a lot of faith in the SHO). No problems so far..
So does anyone have an idea what the problem is?
Tek
J
Jeremy Hohn
Guest
You may be just getting lucky. I would change your cam sensor anyways.
