Another mod meet?
Gez89SHO
LEGO SHO
NE Philadelphia, PA
Yeah Gezim, my crib, as it were.
You've been there, haven't you? Need the address? You've still got my cell number, right? It's pretty easy to get to my place.
Actually if you remember where Arnolds E-Karts is in Oaks I'm maybe 3 miles from there on Egypt Rd. EASY.
Actually I wasnt there before, so the address would help. Got the number still too, so I can call when I come up. BTW I checked and am free on the 1st. I might do a strut mount on mine while there, if there's time.
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
As promised, the reason I need a new suspension and tires...
Just a little bit of strut rub:
Can turn into big damage:
Terri and I were still about 700 miles from home in GA when this happened. I'm getting some Avon Tech M550's from Tirerack as soon as my guy gets back to me. Hopefully by the beginning of next month I'll start to enjoy driving this car...
Click on images for higher resolution.
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
So what's the consensus on the rear sway bar end links? Do I HAVE to buy them and if I do which ones listed on Rockauto are the best?
Anything else I need to purchase?
RAYJAY
WHO ME ?
UNION DALE PA
MOOG Part # K3124 More Info {Sway Bar Link Kit}
Rr Susp; Sedan; Heavy Duty Design 11.95
same one I used on my 94. also will be doing the full suspension on the 93 shortly ..... may be yellow struts on the blue car ........
Jeff
PAracer
West Chester, PA
No, you don't need to buy them.
It's one of the few items that can be replaced in a few minutes when one of the originals break. I would skip them if you are trying to save money.
To do the job as quickly and cheaply as possible, all you need are your quickstruts.
BTW. If the spot welds on the front strut towers have been cut, mark where the camber plates are sitting so that we can put them back into place in the exact same place. This will save a trip to the alignment shop.
It would also be a help if you could use a can of PB blaster in as many places as you can reach the night before.
All four pinch bolts, outer tie rods, caliper to knuckle bolts, sway bar links, rear control arms. Basically anything that might need to be removed or separated. We should be able to do the job without pulling the front control arms and strut rods.
It would nbe nice if you have a long pry bar for popping the lower ball joint out of the front knuckles. I use a 6' bar inserted over the LCA and below the subframe. A little force is all that is needed to pull them out.
PAracer
West Chester, PA
Also need to remember to keep the old struts as housings for Koni inserts. Prepped and painted, you should be able to get a few bucks for them.
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
Jeff, I think those are what I was looking at on Rockauto. Thanks.
Good idea Mike, I might just have to do that. Heck I might do it for me down the road after I get money to go racing again. :D
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
Just letting everybody know that tomorrow is still a go. I bought some fresh chicken and I have a few burgers I can throw on the grill. :D
Also, a question. Didn't the Gen 1's come with solid rear brake rotors? Mine are vented... It's also got the Gen 2 brake upgrade up front. LOL That was pretty nice to find out!
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
Well, we managed to get the suspension on the car along with some new tires that I mounted and balanced. Lo and behold one of the wheels is bent :madflame: so now I need a new wheel. Anyway. The rest of the suspension and brake components looked good but I think I do need new slider pins and boots for the rear calipers and new sway bar end link bushings on the rear. Other than that everything was great and broke apart pretty easily.
Many thanks to Bob, Mike, Eric, Gezim, Matt, Darren and the other little one that helped with the groceries. :snicker: James? Jason? Jamal? I'm pretty sure it was a 'J' name. :nut:
Pictures.
Terri Huffnagle
PA
I'm sorry I missed everyone - I heard you had fun in the midst of all the projects. I certainly could've changed my O2 sensors in the mix.
Unfortunately I have a 'priority project' this weekend at my house.
Hopefully we can hook up "soon" at Kildare's or something. We should still have decent weather for a while. We can also hope for another 70* January day but let's not wait that long!
Fords at Englishtown is November 3 & 4 this year...
Terri
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
Yes, everybody was asking for you but I already told you that.
Um, BTW, who's got the keys to my bimmer? LMFAO!!!
