Another Fuel Pump replacement (hole cut method) thread
Yeah the first sho I had was a norther car. That's why i said just cut the straps if necessary. You could get lucky with getting them out with the door cutout, or you could do all that labor for nothing and still have to drop it. Wish I could make it easy with a good yes/no answer. Is there a pic with the tank out? There has to be enough room to wiggle those things out. It can't be super tight and risk rubbing a hole in those lines
Besides, don't you snake replacement brake lines over the gas tank if you have to replace them from the prop valve to the rear wheel on the other side?
