doclees
I think I posted this in another section but didn't get much response.
I have 2 R12 systems to convert to 134a..maybe. efproducts.com says you don't need to open your system and remove the mineral oil before filling with 134a and PAC oil. Specifically states that GM says you do not need to change O rings.
on the other extreme I am told and read that you need to evacuate, flush, change the compressor, o rings and accumulator/dryer, reassemble and re-evacuate. Then recharge.
I think my GM system is just a little low on R12. If I could get an R12 charge at a reasonable rate I would just do that. My 93 SHO has a very rusty accum/dryer so I think changing that out is going to be necessary.
Is the truth out there? Can you do a successful and non-damaging closed system retrofit?
Doesn't make much sense to replace a working compressor.
