and the TURBO rides again...
Toolman
Boost it!
Grand Lake, Oklahoma, USA
which is good news, but, the bad news...I AM A FREAKIN' IDIOT!!!!
So tonight, for the first time since before the convention, I decide to really tear into this thing. For those that did not read the other threads, here is a brief synopsis:
Completely revamp turbo system prior to Indy Convention (new turbo, WG, BOV, trans, clutch, get Tweecer, wideband 02, the whole works). Go to start the beast after I have sewed everything back up (in like a week, with a broken and hurting leg!). SHE WILL NOT START! No juice to starter, unless I short across the relay, and no juice to fuel pump, no matter what I do. So, after messing with it for hours, I give up, hop in the nearly stock blk/blk + and have a grand ole' time at Indy.
So, FF to after convention. Car needed a battery and ignition lock anyway, so I purchased those. I removed/cleaned all ground wires, got new cable clamps, and replaced ignition switch, STILL NOTHING! I was getting frustrated. I knew it was something amazingly simple that I was overlooking, but I just could not put my finger on it.
FF to now. I have been crazy busy for the last two weeks, have not done a thing to the turbo, and so tonight I get the tools out, get the drop-cord, and get ready to find out what is going on. My starter relay bolt was stripped anyway (power to the starter), so I got a new unit. Replaced that, put back my old cables on (glad I did not purchase new ones) and started tracing every wire in the harness. I removed intake (really dirty anyway, along with my valve covers) cleaned it up, and continued my diagnosis.
GUESS WHAT I FOUND!!! And someone mentioned this to me in one of the threads. Dang me for not looking it up right away. The harness connections sitting below the TB and above the trans, THE CONNECTIONS WERE SWITCHED!!!!!!!!!!! Dang my color-blind ****, and DANG FORD for making them interchangeable!!! So I knew this had to be it. I put everything back together (cleaner now), powered up my wideband, and started her up.
I CAN NOT FREAKING BELIEVE IT!!! A stupid connector was all that kept the turbo from being at the convention! And then I could have had it tuned by the best! While I am relieved to have it running, I am upset with myself for missing out on that great opportunity all because of a stupid oversight on my part. VERY FRUSTRATING!
Anyway, now I just need to get it Tweec'd. It ran for a while, but only if I kept my foot on the gas a bit, and for some reason the fuel pump was running wide open on the dip switch setting I was on, so I likely need to reflash the correct program in it. As soon I get it running well enough to get some datalogs, I am going to get some assistance in getting it tuned well enough for a dyno session. I have a feeling the numbers that will result will make this entire mess all worthwhile!
So, moral of the story, two parts: One, pay attention to the small stuff, it can come back to haunt you. Second, USE PROPER LIGHTING!! Had I used sufficient light while I was working on her before (found it very quickly tonight with my light shining in there), she would have been at the convention.
So, happy trails, until we meet again (with 500whp!!!)
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
sweet.
So how many new gray hairs do you have? :naughty: :biggrin:
And can I plan on seeing this beast at next year's convention? Seeing that Im driving cross-country again? :dribble:
DavidT
TN
well, hey, at least "problem solved" :thumb:
SinisterSHO
Rust free
630, IL
Party at Tims!
Glad to hear its running. I would still really like to come down and hang out with you for a weekend with my buddies so they can experience the Turbo SHO. However, with it getting closer to winter, I dont know if we'll be able to before it gets too bad. Unless you want to make a trip to Illinois? I know a few cars that need to be blown off the road by a SHO. :evilgrin:
PROPHET
Well-Known Member
Tonytown, Texas.
Al would have found that for you in a jiffy, Tim.
http://marge.uvm.edu/sdempse/images/TV_Movies/Home_Improvement/Al.gif
1slickRED89
Guest
Toledo Ohio
most agreed!! plenty of good light and a clean, organized workspace make tough jobs more manageble.
In fact, I just picked up a track light kit ($25) and three reveal R-type 65 watt bulbs ($24, 10 hp each for the R-type BTW) and it transformed my shop, from a shop to a showroom. no matter where i'm standing i have light on the car, it's great.
Glad you finally found the problem Tim. This is why with my ADD I make sure I have a roll of masking tape and a pen to mark every connector. I would go crazy trying to remember what went where. :banghd:
DHMag
Free At Last
InCahoots, Texas
that was me that mentioned the 2 connectors being switched, so wheres my $100 ? :)
DHMag said:
Tim, you mentioned you had done some work on it but nothing electrical. did you at least disconnect any wire harnesses ? if so, there are 2 gray ones above the trans that have the same pin configuration and will swap each other male/female. ive tried this on my personal car and it creates a crank/no fuel pump prime/run condition. id have to go look again but would you like a picture ?
shojuan
sunny San Juan Bautista,
You too? :doh:
WesternMassSHO
SHOwner
Springfield, MA
Glad to se it's zipping along once again! TwEECe the **** out of it and get it dyno'd!! The numbers on that thing sound like they're going to be sky-high!
Congrats! :thumb:
bmytych
