shoteen95
isn't a teen :D
I was wondering if you had any input/comments on my crazy system ideas...please keep in mind, i'm an audio newb, and all that i've "learned" so far tonite has been between 12am and 2am...or from ripping out the stock sytem from one car and moving it to another.
I want to upgrade the stock system and was thinking about a nice higher quality polk audio or infinity subwoofer. I hear the stock box performs reasonably well with an 8 inch woofer, even the 85 watt amp can power some smaller aftermarket woofers, altho not to it's full potential. Anything i could do using the stock amp and wiring is really appealing..ease of use maybe..dont know how easy it is to adjust the bass when you have a system and you're going down the freeway.
I was also considering a 8 or 10 inch q-logic truck box, the sealed ones are relatively small, and the idea of mounting it under the rear deck has crossed my mind. I would just have to make sure it was sealed up up to the cabin well, and that however i mounted it wouldnt comprimise the seal of the box.
Settling on a more expensive 8 or 10 inch sub I would most definately be in the market for a better amp. From what little i know, i can splice into the stock speaker wires (before the 4 channel amp, and assuming my new amp had speaker level inputs) and run wires to an amps high level inputs...then all that would be required was a juicy power cable to the battery with an inline fuse. Although, if i remember correctly, my headunit has a preamp out just for a subwoofer amp. i know in its menu it has a subwoofer volume adjustment. Originally i didnt want to tear up my carpet and run RCA's, thats why the idea of just splicing into the speaker wires in the trunk was appealing, but i suppose i could run an RCA cable. Mounting the amp in place of the stock jbl amp would look pretty slick.
Mostly i'm just trying to stay away from the giant speaker box filling the trunk and having a giant amp sitting next to it. I don't need so much bass that my spoiler rattles off my car, either, but yea...more then stock would be much welcome.
Thanks
P.S. I Still have time before christmas, anyone know of some relatively cheap components for this build? I was looking at a sealed 8in q-logic truck box that i think i could mount under the rear deck somehow, it was about 50 dollars. As for a sub, I only looked at a Polk/Momo 8 inch..not sure how much they go for. Amp wise...i have no clue..it'd be nice if it were under 150 dollars.
Sorry i said a mouthful..thanks again
i need sleep
Thanks
i need sleep
ive heard one set of paper ones (some 10" mtx's w/black cone, dont know what they were) and didnt like them much, but it may have been some other factor in his system?
