Amsoil=hp
Sammy~D
Wrench Whore
Anoka, Minnesota
hey i just was talking to my buddy in texas he has a sho and is running all amsoil in it and he said it gave him some good hp improvements the oil i guess was smoother flowing so it worked quicker and he just changed it and no whear or problems...so i just bought some from him and damn it works good....he gets is cheap ass **** so if you want any let me know...for any amsoil products
dmoo21
el oh el
St. Louis Park, MN
dyno slips please. ams oil verus any other regualr oil
i do not see how your choice in oil will geve you more HP to the wheels.
wuzzzer
MN Moderator
St Cloud, Minnesota
I'm not sure how oil can do that? I understand there are different viscosities to oil but I can't honestly see anyone seeing a noticeable enough difference to be able to say "damn it works good." ?
Maybe I just don't know enough about oil?
Minnesho
i was wrong
MinneSHOta
with similar products like royal purple you may see a couple ponies on a dyno but nothing you would feel. and only if you used it through the whole drivetrain.
93rev2sev
Hockeytown
Oil starts to break down and get contaminated from blow by. Some better oils resist breaking down. And some have additives that are designed to break up pre-existing sludge deposits.
Amsoil might not break down as fast as dyno-oil, and it might even help clean up deposits and sludge...allowing the rings to seat and seal better...I suppose it's possible that this can slow down the contamination process and free up a miniscule amount of HP.
BUT...if you change your oil regularly, there wont be deposits because the oil hasn't broken down. And there wont be contamination because the oil is changed before it gets contaminated.
I would try Amsoil if it were free but I think I'll just keep changing my castrol high mileage blend regularly. It, too has been designed to break down sludge deposits. It also boasts the ability to recondition seals...thats a big one.
Using regular old "dyno-oil", I started to notice a puff of smoke at start up. Most people I talked to said that the valve stem seals were allowing oil to leak into the combustion chamber. Switching to "high mileage" synthetic blends has apparently reconditioned the valve stem seals. Now I never see that puff of smoke at startup. In the rearview mirror, I notice less "blowby" smoke under high RPM loads.
I guess what I am saying is...amsoil or castrol or mobil synthetic...as long as the additives are there to recondition seals and break down deposits, you CAN experience less oil consumption.
Less consumption means less oil in the combustion process. Which in turn means more complete combustion, less fouled plugs, and more power.
Troubled93
Charlotte, NC
my cousin is steve scheuring the owner of scheuring speedsports...the Polaris AMSOIL race team... i will get in touch with him to see if i can get some mass quantities of all fluids...oil, trans, and coolant... if i can i will let u guys know... i am pretty sure he will get me some so i will just keep you guys posted
NJSHO
Clean Your Shorts!
NJ
If its synthetic oil, then the +1HP can be attribituted to less friction due to the molecule size of synthetic oil. I believe there is an article some place where they dynoed a car then replaced all the fluids in it with synthetic and gained a couple of hp.
This isnt the link im talking about, but it is on topic go down to lubricants
Sammy~D
Wrench Whore
Anoka, Minnesota
when i said damn it works good it is because it did help things seal up and cleaned every thing and damn made it work great...clean engine is good....but im running all the fluids...Supershift Racing Transmission Fluid...and the oil is Series 2000 Synthetic 0W-30 Motor Oil and the AMSOIL Ea Oil Filters
