BenBrausen
I'm gonna go ahead and install my subs in my car. I was just wondering where the best place to run the power wire through the firewall and through the car is? I'm gonna be goin' with a 4ga, 2ga, or 0/1ga wire......
You can go that route but if you purchased a amp install kit, they give you enough wire to go the other way across the engine bay.NorthernSHO:
If you open the passenger side front door, there is a rubber gromet near the door hinges that goes into the passenger compartment. Once you put the power wire through this gromet, you can then feed the wire into the front passenger side wheel well. You will need to remove the front passenger wheel and the fender liner. From here you can easily run the power wire directly to the battery out of site and out of mind.
Any questions, let me know.
Why do you need that much power?? With a well thought out and designed system, you can get away with 1000 watts or less(bass only, even less power with mids and highs). Every 1000 watts rms, you need a 1 farad capacitor. If you do want to run 4000 watts, you will most deffinately need bigger than 2 awg.BenBrausen:
As of right now, I'm just runnin' 2000watts with a 1 Fraud power cap. I will be goin' up to 4000watts sometime in the near future.
Which company are you going with ??RickieFrat:
If your going that powerfull what are you useing to push it ???
farad thumbs_uBenBrausen
When I do upgrade to 4000watts I'm gonna add in a 5 fraud cap.
