aluminum subframe bushing installation
Bank of SHO
Vegas
The subframe is off the car for the clutch service. I'll install the ASBs soon. Is there a procedure for doing it while the subframe is out? Is there anything I have to do to the subframe before installation? Any details you have to offer will be appreciated.
Thanks,
Tom
shojuan
sunny San Juan Bautista,
Just remove the stock bushings and put the aluminum bushings in their place. There are four little nuts on each bushing to remove. Also remove any little rings or spacers that are installed. Some cars have them, some don't. Mine didn't. Use new bolts (best source for quality bolts is a pair of subframe recall kits p/n XF1Z-5A364-AA. Use the washers that come with the kits between the bottom of the bushing and the bolt.
The hollowed out (female) Al SFB half goes on top. The male half goes through the subframe hole from below and into the female half. Also, when reinstalling your subframe don't raise the subframe with the bolts. Raise the subframe with a jack and support with jackstands (or better yet use two jacks) until it makes contact with the body and then snug up the bolts. Then loosen them a turn or so and align the subframe using the Helms procedure which is the following (really simple):
Take an 18" or so length of 3/4" outer diameter pipe (1/2" EMT electrical conduit is just about perfect. It's dirt cheap. Take a hacksaw with you to the hardware store in case you need to buy a big 10 foot length like I did and you don't have a truck like I did. That way you can cut it into a few pieces to fit in your car). Just aft of the front subframe bushings there is an alignment hole on each side, both in the subframe and in the body. You stick the pipe in the driver's side hole and align the subframe so the pipe is sticking straight up and down into the holes. I used the pipe as a lever to shift the subframe around and it slid easily (The fact that I put grease between my subframe bushings and body helped! eek! ) Then tighten that front driver's bolt. Then go to the passenger side alignment hole and do the same thing: stick the pipe through the two holes and shift the subframe if necessary using the pipe as a lever until it's sticking straight up and down through both holes. Then tighten that passenger bolt. Then tighten the rear subframe bolts. Although spec is less for stock bushings I tightened to 100 ft-lbs. I think some people have tightened to 120.
Also if you want to set your caster to maximum you would do pretty much the same thing while aligning the subframe EXCEPT once you have the pipe sticking straight up and down through both holes then use the pipe as a lever to pull the subframe all the way forward and then tighten the bolt while holding some tension on the pipe. Repeat for the other side and then tighten the rears.
Also, I wouldn't mind getting some people's opinions on using grease between the subframe bushings and the body. I haven't had any problems so far and I figure A: the torque on the bolts will hold the subframe in place. B: the grease helps dampen some NVH. I certainly don't have any that I find noticable much less bothersome. C: if it causes me problems from the subframe alignment shifting over time then I will just drop each corner a bit and spray brake cleaner through the gap to clean the grease out.
Anybody think that grease is going to be a problem?
<small>[ August 18, 2003, 02:52 AM: Message edited by: shojuan ]</small>
K-Dawg
Treasure Coast, FL
shojuan:
I've read this many times before, but what is the reasoning for not using the bolts to raise the subframe?
I wouldn't think the grease would cause any problems.
shojuan
K-Dawg:
shojuan:
The devil will come out of the body holes and whoop your ass!
I don't know, stresses the threads too much lowering their long term durability? Yeah, a better explanation would be nice.
Ishodu
As far as lifting the subframe with the bolts. Well reasons I can think of are it would be harder to tell if the bolts are cross threaded, and the torque reading maybe be set off from the weight. But what do I know. shrug
Bank of SHO
Vegas
Thanks for the nice write-up. I won't be able to get to it until next week though. I have friends visiting. I'm still wrestling with the tranny too. The liitle things, it's always the little things.
poffffd
