Aligning a lowered 2010 SHO
PltwhtSHO10
How's it going everyone? I just got done lowering my 2010 SHO with my Old Man via the H&R springs I purchased from Livernois. My question is, can the caster and camber be adjusted after this has been done when taken in for an alignment?
If not, are there options with caster and camber plates that anyone is aware of?
Thanks in advance for the help.
Crash712us
Chasing my tail
MI
There should be enough adjustment to get you aligned. Some however have had to use cam bolts on the rear to bring it into alignment.
Dave
SHO Lover
Wisconsin
I don't think you can get the day but inside the door jam should have a sticker with month and year.
Try etis.ford.com and putting in your VIN number after clicking on VEHICLE in the VIN Entry box. I did get a build date (DD/MM/YYYY) off of that. Hopefully yours will be on there as well.
