Airbag code 6 after gen II wheel swap
SHOPLUS
Ohio
When I bought my 91+ months ago it flashed the code for front air bag sensor. I replaced it at the same time as doing a wheel swap and now it continually flashes code 6 for the driver's air bag circuit. When I did the wheel swap I used crimp/butt connectors to swap the connectors. The write up said to solder but I've always used butt connectors when wiring. Could this be the problem?
kevinspann
Don't take my advice.
Richmond VA
Yes, I suppose it could be. Horn and everything else work? Could be the clockspring too. You made sure it stayed centered, right?
SHOPLUS
Ohio
Yeah the horn works and so does cruise. Its had an issue since I owned it where cruise would just randomly cut off while driving and could be turned back on and work fine. Its a pretty rare occurrence and happened before the swap. The wheel was kept centered. I guess I'll pull the bag soon and solder the connections to see if that changes anything.
