Liquid_force
My A/C worked ok most of the summer.
About a month ago I got smart (i.e. stupid) and decided it wasn't blowing quite as cold as it should be so I got my gauges out to play.
I have an interdynamics chart of high/low pressure ranges according to ambient temp and the readings I was getting seemed pretty high.
So - being the smart guy I am I decided it would be helpful to bleed off a little refrigerant (sorry EPA).
That was a bad idea. Since then I've had a semi-cool (at best) ac. I've added back some 134a but I've seen high side pressures at 350-375 and I think my chart says it should be more like 275-300.
Low side seems to be fairly steady at 40-45, but will swing as much as 20-50 with idle speed changes and compressor cycles.
I know, I know -- I should just take it somewhere and have it vacuumed and recharged with the correct amt -- which I will likely do next spring, but the hot season's winding down and I'd rather get it through the next few weeks on my own.
Basically I'm just curious if anyone has monitored their AC pressures and what they typically run at on a hot day -- idle & ~2k.
