aftermarketd cd player..help
fast-r-sho
valdosta,GA
Well i installed a aftermarkrt cd player and i tried to use the factory amps and the speakers will not work unless i bypass the amp with the jumper wire from my other sho...any suggestions would be greatly appreciated..by the way i checked the fuses<img src=http://beautifulomega.com/sho/slicersho1.jpg>
[This message has been edited by fast-r-sho (edited 01-11-2002).]
RickieFrat
La Cosa Nostra
State of Corruption - RI
You have to send power to the amps for them to turn on. If you used a wiring harness to "clip" into the factory harness, you have to make shur the blue/white stripe is connected to the same color wire coming out from the aftermarket radio. This wire will send a power signal to the amp when the radio is turned on. You should also have your power antenna connected to the same wire coming from the radio.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
