Hi, after years working on this project im getting somewhere, the car is a 67 ford osi, rare Italian car, Ive got the 90 sho motor in and running using a adapter and the 5.0 bellhousing and t5 transmission, Im trying to wire the original tach to the sho pcm, the original tach triggers off coil negative, Ive got the trigger wire connected to pcm terminal #4. it isn't working, I have also bought one of those boosters but still nothing,has anybody wired a aftermarket tach into a first gen sho. This is driving me crazy, ive run codes on it and everything is good except for the things that im not using power steering, purge cannister, brake on brake off, are the only codes I have showing. I checked the voltage at term #4 and theres .1-.2 volts running
any help would be great
