Bradley
Trying to set up a group buy for these aftermarket seat heaters...www.seatcomfort.com
I can get these units for $85 if we get at least 10 orders. They are normally $105...Real good savings!!! All you have to do is PM me if you are intrested, and when we have enough people you call and place your order with a special discount code i will provide you with and they will be directly shiped to you.....straight from the manufacturer!
Ford seats are easy to pull apart. The kit will work with cloth or leather seats. The kit includes EVERYTHING you need and ill be glad to do a write up as soon as i get mine on how toy install em (mad easy). Basically, you pull the cover off the seat and place the heater element where you want, secure it with clips or wire ties, and put the seat back together. You can get power from the power seat connector under the seat. All you got to do is drill a hole for the dual setting swich (high/low).
The price above is for one seat...this means you are supplied with two (2) heater elements for your butt and back. each are 11*22". They are dual temperature and thermostat controlled. These will work for almost any car. they can be cut and holes can be punched in em as well.
If you have any questions, lemme know, and as soon as i have 10 orders (that means 10 heaters, not 10 seperate people, you can order and have the units within a week!!!
