OgreSmash
I just replaced one on my 2010. didn't need a hub puller or none of that crap. 32mm socket with breaker bar for axle nut and socket set for the 4 bolts that hold the hub on. had mine changed in 30 minutes
Was it ever replaced before? Are you the first owner? If it was done once before, it would probably drop right out.
I am at 53k and noticed a squealing / metal slinky like noise when I turn the steering wheel left - not every left turn, but I only hear the noise when I turn left. I thought it was way too early for a wheel bearing to go bad. Looks like I have a weekend project!I remember having to have the front bearings replaced at 20k miles on my 2010. Warrantied and fixed the issue. Crazy low mileage for problems though. The tech said they were all like this.
I went with the SKF. I had no problem getting the hub off. I pretty much just wiggled it and pulled if off with my hands. I spent more time wire brushing the knuckle. Everything else (CV, tie rod, etc.) looked great. Anyway, I noticed the RedStuff pads were almost completely worn down, Less than 1mm of pad left. Its only been 11,000 miles!! Is that normal? Replacing front brakes this weekend. I hope this fixes the squeal issue. Its so embarrassing!!
if you drive your brakes hard maybe that is why only 11,000 miles
